So I'm using radarr and qbittorrent. Normally when I request a movie in radarr, it would add a torrent and then qbittorrent would match the download name to the folder/file name exactly but that is no longer the case.
I need the download name and the folder name to be exactly the same every time, automatically. Is there a way to achieve this? I've attached an example of the issue/what I need to match by default.
I'm not sure if this is a bug or an errant setting. It used to work correctly until I updated the program so I do presume it's a bug. Ultimately I don't care if the folder name is automatically changed, or the name in the torrent download directory. As long as they match and it's all done automatically radarr will be happy again. Thanks for any help!
Downloaded the new update, folder names no longer accurate
- incorrect name.png (3.55 KiB) Viewed 902 times
