Hey there!
Re: Hey there!
Before I get started, is it yet supported for Mac Big Sur latest patched version?
Also, If you like me to do some QA tests for pre-release versions for Mac OS I can do that too ;D (for free!)
I can build STP,STD doc's etc.
Honestly, the project is in dire need of OS X devs in general. Having the M1 is just icing on the cake.
The current builds AS FAR AS I KNOW are not exactly well tested over OS X.
Also I think M1 should benefit from building it for ARM instead of x86_64.
Unfortunately, it's really hard to comfortably emulate OS X on Windows.
