A problem I encounter
barakud
Post by barakud »
Hello,
While using the amazing qBittorrent I encounter a problem. The software is running wonderfully but the other internet isn't working correctly. By this I mean it's actually unavailable to use the internet. I ran the Microsoft
internet diagnostic utility and it display this:
WinSock status
info All base service provider entries are present in the Winsock catalog.
info The Winsock Service provider chains are valid.
error Provider entry MSAFD Tcpip [TCP/IP] could not perform simple loopback communication. Error 10055.
info Provider entry MSAFD Tcpip [UDP/IP] passed the loopback communication test.
info Provider entry RSVP UDP Service Provider passed the loopback communication test.
error Provider entry RSVP TCP Service Provider could not perform simple loopback communication. Error 10055.
error A connectivity problem exists with an installed LSP.
HTTP, HTTPS, FTP connectivity
warn HTTP: Error 12029 connecting to www.microsoft.com: A connection with the server could not be established
warn HTTPS: Error 12029 connecting to www.microsoft.com: A connection with the server could not be established
warn FTP (Passive): Error 12029 connecting to ftp.microsoft.com: A connection with the server could not be established
warn FTP (Active): Error 12029 connecting to ftp.microsoft.com: A connection with the server could not be established
warn HTTPS: Error 12029 connecting to www.passport.net: A connection with the server could not be established
warn HTTP: Error 12029 connecting to www.hotmail.com: A connection with the server could not be established
error Could not make an HTTP connection.
error Could not make an HTTPS connection.
error Could not make an FTP connection.
I would appreciate your help.
Thanks friends
ironcross
Re: A problem I encounter
Post by ironcross »
Maybe you must limit your connections and speed in qB, if it's using the maximum of your internet connection. Error 10055 means that Windows has run out of TCP/IP socket buffers because too many connections are open at once. Error 12029 means that you can't connect to the requested web server and this is a consequence of error 10055.
barakud
Post by barakud »
How many connections may my computer have?
How should I use them with upload and download connections.
I have win XP, intel E7500,  2GB RAM and Sagemcom F@st 3184 in my computer.
thank you very much.
Tomaso
Post by Tomaso »
Yes. You won't be able to take real advantage of P2P software under Windows XP before you've patched tcpip.sys.
The "Event ID 4226 Patcher" command line tool that ironcross linked to will do the job..
As an alternative, you can use XP-AntiSpy (freeware):
http://xp-antispy.org/en/
..It's got a simple GUI that lets you enter which ever max connection value that you want (under "Special" > "Connection limit").
Also, the program comes with a bunch of other tweaks for Windows that you might find useful.
