Can't remove torrents "Not Found"
Wolfshare
Post by Wolfshare »
I have tried using the trash can in the WebUI to delete a torrent and I get a dialog box that simply says "Not Found."
Screenshot 2021-01-10 194130.png (4.57 KiB) Viewed 1188 times
I have tried with torrents that haven't downloaded, completed torrents, etc and I get the same dialog.
I also can't check hashes for torrent files I created and uploaded to a tracker so I'm not sure that's related.
MicahMakenzie
Re: Can't remove torrents "Not Found"
Post by MicahMakenzie »
maybe try cleaning your PC's cache (from various applications, including torrenting) or doing an advanced cleaning of all residual files. try something like CC Cleaner
