History / Completed Torrent map needed
mrdummy
Post by mrdummy »
Hello.
I'm old utorrent user, and i'm now checked your torrent client. I always use map system in utorrent for downloading and completing.
There are 5 maps:
1- for completed files (/incoming)
2- for temp files in progress (/temp)
3- for just added torrents and in progress (/torrents)
4- for finished torrents to copy/save here (/history)
5- for reading new torrents automatic (/read)
Points 1,2,3,5 are found in your client, but i cannot find settings for point 4. It seems you have forgotten to add this option in the settings. Please add this.
The simple reason is that i want save and keep the finished torrents for my own history. If some files might gone corrupt or deleted by accident or i don't know where, then i can get it from history.
Also i can check there if i have it already downloaded or not.
By default, you can make map "%appmap%/history".
Can you add the feature very soon? Then you have almost same as utorrent and many users will come here.
Thank you very much.
mrdummy
Re: History / Completed Torrent map needed
Post by mrdummy »
No one answered here and it's good feature. Thus i will bump this topic up.
Dayman
Post by Dayman »
There is "copy .torrent files for finished downloads" pushed to git already, if that's what you want, otherwise you can always post on the bugtracker https://github.com/qbittorrent/qBittorr ... state=open
Sledgehammer will make another official windows build after he gets back from RL, I'm not very confident in mine builds.
