Hello,
Just like the titels says.
All the torrents are in the wait.
Seeders enough...
Poorts are open.[ work fine by Utorrent
All the torrents are in hold
Re: All the torrents are in hold
Check your network interface setting... Go to "Tools" -> "Options", click the Advanced button, select "Any Interface", apply the settings, close and restart qbittorent. This happened to me for some reason and I had the same issue.
