QBT Disconnects Internet CNX
Groggz
Post by Groggz »
hi, firstly great program. it worked flawlessly on my old intel pc. but my "new" amd pc has problems. Basically, the internet will disconnect completely from the PC whilst QBT is running. It will reconnect within a 10-20 secs, but can occur repeatedly within the space of 1 min or sometimes not for 10. Ive tested many scenarios and it only happens whilst QBT is downloading/uploading.
My AMD X570 Board is an MSI MAG Tomahawk. running latest 10.46 ethernet drivers for its realtek adapator.
My Router is a google nest wifi device. the pc is connected via ethernet, not wifi.
Any ideas?
Re: QBT Disconnects Internet CNX
Simply lower connection count in settings. Don't worry it won't ruin your speeds.
