VPN's that allow for share ratio's?
HapHazard
Post by HapHazard »
Can anyone suggest a VPN that maintains share ratio's?
I am not that experienced here,but I did see a video that stated not all VPN's are able to maintain share ratios for those torrenting sites that require it.Can anyone share advice on what VPN'(s) could fulfill that requirement,or what I should be looking for? Thanks for any help.
Hap
Re: VPN's that allow for share ratio's?
Some VPN have port forwarding.
- Windscribe has port forward. (If I remember correctly, you have to purchase a Static IP from them, and then you can do it.) There was a deal here [ https://stacksocial.com/sales/windscrib ... bscription ], not sure if it's still active. CODE: SDWSVPN21 - via: [ https://www.reddit.com/r/Windscribe/com ... years_pro/ ]
- Mullvad has port forward.
Honestly, it's best if you just buy a cheap seedbox in my opinion. Like PulsedMedia is pretty super cheap in my opinion.
But, it's your choice.
Ps.: qBittorent and us, the team/admins (myself included) are not associated with any of these companies in any way.
