Main client connecting to qbittorrent-nox
peaveyman
Post by peaveyman »
Is it possible to have the main client connect to the daemon instead of having to use the webui?
Re: Main client connecting to qbittorrent-nox
You cannot connect the client to a remote -nox/webUI like with transmission.
qBittorrent can either run with -nox (no GUI, webUI only), or the GUI version (which can also enable/run/host the webUI).
