Windows 10 blocked Qbittorrent
degete
Post by degete »
As of today, Qbittorrent doesn't work any longer on my Windows 10 machine. At first, I noticed the Qbittorrent shortcut was deactivated. I tried to reinstall the application, and it appeared that Windows did let me reinstall it. However, at last step, when I tried to open the app, Windows Defender blocked it. Even if I set Defender to allow this app, it still doesn't work. The app worked flawless until today. Interestingly, the same thing happened with other torrent clients that I tried to install. I have the impression that Windows just modified its policy regarding torrent clients. Did anybody else experienced the same issue?
klint
Re: Windows 10 blocked Qbittorrent
Post by klint »
Same here :)
diavolo599
Post by diavolo599 »
Same here.
ElHugoCK
Post by ElHugoCK »
Same problem here. There is a report of the issue right here: https://github.com/qbittorrent/qBittorrent/issues/14489
https://www.reddit.com/r/qBittorrent/co ... microsoft/
Nothing to do with qBittorrent, Windows Defender is acting weird again..
diavolo599
Found out, that 4.0.0 version still works and windows defenders does not consider this as a threat.
Older versions:
https://sourceforge.net/projects/qbitto ... ent-win32/
Of course it works, all outdated software probably works but if its advisable is the second question.
No support and use at own risk.
nl255
Post by nl255 »
Nemo wrote: Mon Mar 08, 2021 12:48 pm Of course it works, all outdated software probably works but if its advisable is the second question.
Well the only other solution on Windows 10, short of installing a different antivirus program (all the free ones suck) or disabling windows defender entirely (definitely not recommended), is to disable PUP/PUA (i.e. antispyware) scanning in defender. Whether or not that is more risky than using an outdated version of qbittorrent I have no idea though at least on pro (and enterprise, of course) you can mitigate that by using software restriction policies to make specific folders non-executable so that you don't accidentally run anything from your download folders before you can check it with virustotal.
