how to massively change the passkey?
arthar
Post by arthar »
how to massively change the passkey? you need to change the passkey for 565 torrents..
who knows?
make a button like this
Re: how to massively change the passkey?
I think you can change it with a simple tool, nice and easy.
Just go into the qBittorrent app data, find the .torrent files and do a replace ALL. I believe this should work.
DO backup everything beforehand though.
What tool can do this?
Notepad++ can do it. ( https://www.makeuseof.com/tag/how-to-fi ... ple-files/ )
And there are other tools as well. ( https://www.raymond.cc/blog/search-a-pa ... ext-files/ )
App Data folder path: %LOCALAPPDATA%\qBittorrent\BT_backup
