upload problem...
sturmtruppen
upload problem...
Post by sturmtruppen »
Until a few days ago the program worked fine, then I must have changed something (which I don't remember), and now only users who use Qbittorrent as a client can upload. Any suggestions?
Thanks.
Re: upload problem...
Well, a new version was released recently, but if you check the Changelog, there is no change like that: https://www.qbittorrent.org/news.php
Are you SURE nothing changed on your side?
sturmtruppen
Thank you very much for your answer,
I'm not sure, but may be that I was using version 4.3.1 before ...
Please, can I send you some log or setting files that can help you understand where the problem is? Thank you.
sturmtruppen
Hello,
Please, is there anyone who can tell me why only customers with qBittorrent are able to download my files? I reset the modem, uninstalled, reinstalled and reconfigured qBittorrent 4.3.5, but nothing has changed ...
Many thanks in advance.
unseen19
Post by unseen19 »
you can always post your logs in this topic. I'm not sure which settings will ever cause such behaviour but check
- your version (last? nothing in the bug tracker related?)
- encryption settings in your client. Try to disable it if enable
I'm not sure what else can "select" only qbt client.
