Copying torrents with drive location data
Anthony16000
Post by Anthony16000 »
Is there a way to way to copy my torrents with the drive location data included? I'm wiping my pc and everything but I don't know if copying qbittorrent's AppData folder will work.
I don't exactly know how to phrase it properly but I have a bunch of torrents located on several folders on a couple of harddrives that I'm not planning to wipe and exporting all of my torrents and setting their folder and drive locations again would be a pain.
unseen19
Re: Copying torrents with drive location data
Post by unseen19 »
Hi
if the drive letter and paths are matching, as the permissions, it should be fine.
My move will be to pause all torrents prior the wipe, QBT will retain this state. Then move QBT and Data, and force recheck all of them
In the pause state if you missed anything no download will occur. The recheck needs to end with the status "complete" and the "V" flag a the beginning of the line of rechecked torrents.
