How to reconnect qBittorrent to my existing torrents
Jimjams99
Post by Jimjams99 »
Hi guys,
The destination path to my hard drive changed for some reason so okay...I changed the destination path within qBittorrent but now all my downloaded torrents are starting to download again.
I've forced recheck on the files but qBittorent doesn't seem to be seeing the files. If I right click on a torrent and go to Open destination Folder it goes
directly to the correct folder.
So how do I get qBitorrent to recognise that all the nessary files and folders are there and to start them seeding again rather than dowloading them all again?
Thanks in advance
Jamie
Jimjams99
Re: How to reconnect qBittorrent to my existing torrents
Post by Jimjams99 »
Update: In case anyone find this helpful...I updated to the latest version of qBittorent and then I was able to Force recheck successfully
ROMzombie
Post by ROMzombie »
Hello, I have a problem after using the migration tool. Most of my torrents show they stopped around 90%. Upon using Recheck, it goes to 90+% then suddenly displays in the 50% range. I checked the files and they are completely downloaded but won't move to Completed. What can I do?
