How to complete the download of files
darkslayer
Post by darkslayer »
I download a program from direct links, but when the installation failed, somebody told me to make a recheck of files of program and in case of files be incomplete, I have to download the rest.
And the files are incomplete. I don´t how to download the rest. What do I do?
Re: How to complete the download of files
Well, how much are you missing?
90% of the time, it's Windows Defender that removes something from your download (a crack file, keygen, anything suspicious).
The last 1% can happen when your storage is not stable (data loss imminent) or you have some other storage, OS, hardware problem.
Of course if you force close qBittorrent or force shutdown your PC, that can cause corruption too.
darkslayer
This is how much is missing:
- If you click Peers on the bottom, do you see a lot of people with 100%? (Ie.: Do people even have the 100%?)
- If you check Defender's "Protection History", do you see anything?
darkslayer
No, they still in 0% of download.
Yes, I have a lot of notifications
Maybe there are no peers to seed the torrents to you fully? I mean, this is what it sounds so far.. oO
If its a public torrent, you can always add more trackers.
https://github.com/ngosang/trackerslist/
darkslayer
I made the download of file from the link you sent me but I how do add more trackers?
1) On the trackerslist Github site, pick a list.
I just go with "trackers_all.txt" usually.
Once open, click raw button to get a copy-able list. Like such:
https://raw.githubusercontent.com/ngosa ... rs_all.txt
Copy it all out to clipboard (CTRL+A to select it all, CTRL+C to copy it to clipboard.)
2) Simply right-click the torrent(s) in your list - > edit trackers
And then press CTRL+V to insert your list.
You can keep the original ones there of course, just add these ones too.
You can add new trackers to public torrents by default too!
Settings -> Bittorrent, and here it's on the bottom. Just paste the "all.txt" content here too.
darkslayer
I did that and in tab Trackers, the new ones that add, say "not contacted yet"
