See which pieces have been downloaded (single file torrent)
sibbasson
Post by sibbasson »
Hello,
I am trying to figure out if there's a way to see which exact pieces have been downloaded. I've been testing with the latest Ubuntu version, so I can't approximate by looking at the progress for each file (since there's only one file).
The "General" tab displays the currently downloaded pieces in the "Progress" bar in blue, and under "Information -> Pieces" it says how many of the total pieces have been downloaded, but this is not the level of specificity I want.
Is there a way to see more precicely which pieces have been downloaded so far? Using the image as an example, most of the early pieces have been downloaded, but if I wanted to know if piece number 5 out of 11889 has been downloaded, is there a way to check this? Further, is it possible to get some sort of list over each piece and whether or not it has been downloaded?
Thankful for all help!
