How to reinstall an older version? (4.4.0 to 4.3.9 for example)
Archivist
Post by Archivist »
Version 4.4.0 is crashing on me now.
How do I reinstall version 4.3.9?
Just run the installer again and it will overwrite verion 4.4.0?
Then when 4.4.1 (or whatever version number it is) just run that installer to upgrade again?
unseen19
Re: How to reinstall an older version? (4.4.0 to 4.3.9 for example)
Post by unseen19 »
Not tested by myself but indeed I read post about simply reinstall 4.3.9 over an existing 4.4.0 version. I would suggest a backup first to get rid of any issue quickly.
The version 4.4.1 is not out yet so hard to tell but expected this way.
Archivist
Post by Archivist »
Thanks
For some reason I closed out qBittorent 4.4.0 and then opened it again and did not get the crash message.
Not sure what made it work like it was before the crash.
See if it crashes again.
