"Not a bencoded file" error on tracker upload
Howdy y'all. After I updated to the latest edition of Qbittorrent I have been getting this error on Waffles. Is there an easy fix for this issue?
Re: "Not a bencoded file" error on tracker upload
I experience problems with created torrents aswell. Latest v3.0.6 for Windows does not seem to create correct torrent files.
I've ha no problems with previous versions. I had to create a new torrent file with uTorrent which worked properly.
uTorrent created torrent file was almost double the size of the qBitorrent created file, something is not right..
Any torrents I have created with qBitorrent v3.0.6 have been so far been rejected by trackers because of errors.
I can confirm. You cannot even add it to qbt. qbt rejects the torrent with various messages about the bencoded data. I suspect a bug in libtorrent. I will make a bug report in qbt.
This might already be fixed..
[quote="libtorrent trunk"]
* optimized the torrent creator optimizer to scale significantly better with more files
[quote="libtorrent commits"]
merged make_torrent update from RC_0_16
merged make_torrent fixes from RC_0_16
Yes I can confirm this bug. Thank you for the fix.
[quote="samsat"]Thank you for the fix.[/quote]
Don't thank me, I'm only quoting the libtorrent changelog.
I don't even know if those fixes will do anything for this exact problem, it just sounds like they could.
I will try out the RC_0_16 branch and report back if it has been fixed upstream.
Nope. It isn't fixed in the RC_0_16 branch.
Thanks for the input! Looks like I have to go back to v3.0.4/3.0.5 until the issues are fixed.
[quote="Seigo"]
sledgehammer_999's qBittorrent v3.0.5 was built on the same libtorrent version as v3.0.6, which is v0.16.4.
..so if going back to v3.0.5 fixes it, then this is probably a qBittorrent bug.
qBittorrent v3.0.4 was built on libtorrent v0.16.3 though.
And I was coming here to comment on the same thing. qBittorrent 3.0.5 works so something changed in 3.0.6 and introduced a regression.
It probably involves the fix for the issue #133
I updated the bug report. Let's see what Chris thinks.
I have probably fixed it. Awaiting for Chris to accept the fix.
[quote="sledgehammer_999"]
Excellent! Good job!
