Issue with stats
ratiovsego
Issue with stats
Post by ratiovsego »
I recently reinstalled Win 10 on a new computer. I reinstalled qbTorrent too, I made a copy of my (downloaded & uploaded) torrentfiles in the appropriate directory and a copy of my *.torrent files in AppData\Local\qBittorrent\BT_backup and, with v4.4.1 (after 4.4.0 and 4.3.9) at least, I got all my torrents back. But I still get an issue: if, for each one, the ratio is correct (mostly above 1), my general stats show 0.1 instead of 1.4 previously! Very bad for my ego... :o
Thank you in advance if someone can help me with that...
* Edited to make it clearer (even with a picture!) 8)
My individual and global ratios
All ratios 3.PNG (82.7 KiB) Viewed 1020 times
Re: Issue with stats
Next time, you should just backup both folders.
%APPDATA%\qBittorrent
and
%LOCALAPPDATA%\qBittorrent
Just zip them up, or copy directly and things should just work out of the box fine.
