Copy Completed Download to Additional Folder
Vinny1198
Post by Vinny1198 »
Hello, first off I feel I must say that I am very much a beginner when it comes to any sort of tech or coding, with practically 0 knowledge or experience in either case. That said, I have spent the last 2 days now attempting, and failing, to set up a system to automatically copy everything a torrent downloaded to another folder once the torrent is complete.
A brief explanation of my issue, I download only books, and the service I use for that requires that you seed anything you download. Well, my e-reader auto-deletes any new books when adding them to its library (which cannot be stopped) and so I need to set it so that the torrent is downloaded into Folder A, where it can then seed from, and copied into Folder B where my e-reader can see it, delete it, and add it to its library.
I have looked this up, and found out about the "Run External Program on torrent completion" thing, as well as found numerous commands that supposedly work for this, however I have tried everything I have found in every post online about this, and nothing has worked. So, I assume I am obviously doing something wrong, and probably something so simple it was never included in any of what I saw. So, I am here to hopefully get some help.
Edit: I realized as soon as I clicked "post" that I had forgotten to mention some things which may be important. I am running qbittorent V 4.1.9 (would prefer 4.3.9, however I cannot find that from qbittorent themselves and do not trust any other sources of it) on Windows 10 Pro.
