Seeing blocked IPs with reason "IP filter" but IP filter is disabled
colemarc
Post by colemarc »
qbittorrent-nox-static v5.0.2
What is going on here?
Re: Seeing blocked IPs with reason "IP filter" but IP filter is disabled
- Aren't they trying to brute-force the WebUI login? You may want to reinforce your setup somehow.
- Make sure you are always on very-latest version if you have anything exposed on the internet.
colemarc
Post by colemarc »
Peter wrote: Thu Feb 13, 2025 11:59 am - Aren't they trying to brute-force the WebUI login? You may want to reinforce your setup somehow.
They are trying for sure, but why marking the blocked ip with Reason="IP filter"? It seems like it is related to libtorrent IP filter and not to Web UI.
I am on 5.0.3 now.
Other than using https and web authentication, what could I do?
Tunneling through ssh is inconvenient.
CodyRamirez
Post by CodyRamirez »
That’s interesting! It looks like qBittorrent is blocking a lot of IPs, but without an IP filter set, it’s a bit puzzling. Maybe there’s a built-in safety feature at play? Resetting settings or checking logs might give more insight. Hope you figure it out soon—always great when things run smoothly! When I was applying for my dream university, I struggled to write a compelling personal statement that truly reflected my strengths. That’s when I found Academized where I can buy a personal statement online at https://academized.com/buy-personal-statement-online here. Their team helped me craft a well-written, unique, and engaging personal statement that highlighted my achievements and goals. The result was amazing—I got accepted into my preferred program! If you need help with your personal statement, this service is a great choice!
