qbittorent 3.0.9 has problems with stalled
bobinmk
Post by bobinmk »
qbittorent 3.0.9 has problems with the incomplete torrents & magnet links on (windows 7 sp1) if the correct magnets links are copied to add links to torrent, the partially completed files are not detected, even if the incomplete partial files with .!qt exist, it creates another .!qt file instead leaving the pre existing file. Also need to check the files even broken /partial files without being online stall recheck first option.
Another found was in Behavior --> file association with .torrent and with magnets even checked and saved wont show the check /associate when once changed its blanked out wont save.
Still best client , never defeated, some minor adjustments required thats it.  8)
Re: qbittorent 3.0.9 has problems with stalled
[quote="bobinmk"]
qbittorent 3.0.9 has problems with the incomplete torrents & magnet links on (windows 7 sp1) if the correct magnets links are copied to add links to torrent, the partially completed files are not detected, even if the incomplete partial files with .!qt exist, it creates another .!qt file instead leaving the pre existing file.[/quote]
What happens if you disable in the settings the .!qB extension? Does it work as expected? If yes, this is bug in the .!qB handling code.
[quote="bobinmk"]Also need to check the files even broken /partial files without being online stall recheck first option.[/quote]
I don't understand what you are saying. Could you rephrase your problem?
[quote="bobinmk"]Another found was in Behavior --> file association with .torrent and with magnets even checked and saved wont show the check /associate when once changed its blanked out wont save. [/quote]
I don't understand what the problem is exactly, but it might be admin privileges problem in Windows. Can you post a screenshot showing the problem and/or rephrase the description?
loki
Post by loki »
I wouldn't think it would install without admin rights, but could be wrong, did you approve or use your admin password when you installed it?
Also, 32-bit version or 64-bit version of  qbittorrent?
bobinmk
Post by bobinmk »
thanks @ loki you made sense it was admin rights issue ironed out
bobinmk
Post by bobinmk »
Some files it shows I/O error pop up for big torrents on version 3.0.9  what it mean ?
tekko
Post by tekko »
[quote="bobinmk"]
Please specify which qbittorent 3.0.9 version... any of the special versions or the official?
bobinmk
Post by bobinmk »
@ tekko It was qbittorent 3.0.9 32bit official ,
now updated using 3.0.9 the same by sledgehammer special new not found any problem now , if found report it
http://qbforums.shiki.hu/index.php?topic=1865.0
