I am using qB v3.2 alpha, Windows8 64 bit. I was downloading a torrent of size 228mb, out of which 198mb were completed. I was installing some other software and had to restart the system. So I paused the torrent and waited for a min or so, closed qB and then restarted windows. When I reopened, qB showed that only 13% download was completed and still 197 mb was remaining to download, Checked the log and found this -
13/11/2013 17:44:34 - Fast resume data was rejected for torrent XYZ, checking again...
13/11/2013 17:44:34 - Reason: XYZ fast resume rejected: mismatching file size
This has happened while using 3.1.2 also
My question is What can be done to prevent this from happening again?
Preventing Data Loss
Re: Preventing Data Loss
Hmm, the numbers don't add up. The columns show that file size is 228MB, you have downloaded 198MB and there are 197.8MB left!!! 228.3-197.8=30.5=13.35% BUT 198+197.8 != 228
Does this happen only with that torrent consistenly(if yes pm me a link) or with others too? Before the shutdown was the percentage at 13% too?
PS: What filesystem do your disk use? NTFS?
The torrent was abt 85% completed... and after the restart 13%... Had to download the torrent again from there.. I am using NTFS.. This has happened before but at that time I had a abrupt restart and that's why I thought the data loss at that time was because of that.. But this was a clean restart.. When I paused the torrent I also waited for a cpl of minutes to let it stop completely and then restarted the machine..
