at first I’d like to thank everyone who’s contributing to qbit and this forum.
My problem is extacly the same as described here in a thread which is 1½ years old:
http://qbforums.shiki.hu/index.php/topi ... g5022.html
After switching from 3.1.9 to 3.1.9.2 I think I wasn’t able to change the save patch directly at the "add torrent dialogue" to avoid qbit creating the folder which is defined in the file list of the torrent. Instead I now need to rename the folder in the file list which is shown in the "add torrent dialogue" to make qbit to identify the data in the folder. In 3.1.9 I just needed to point to the save patch of the containing files. Then qbit added the folder of the torrent file list to the line which I just had to delete.
Screenshot:
Is there any other way to import existing torrent with changed directory names? What was the reason the save as path is not editable anymore in 3.1.9.2?
Thank you!
