lost webui after upgrade to 14.10
Papampi
Post by Papampi »
So I upgrade to 14.10 last night and my webui is not working any more
my qbittorent version is 3.1.9.2 and cant upgrade to 3.1.11
payam@PAYAM-UBUNTU:$ sudo apt-get install qbittorrent
Reading package lists... Done
Building dependency tree
Reading state information... Done
qbittorrent is already the newest version.
any idea how to get back my webui ?
Papampi
Re: lost webui after upgrade to 14.10
Post by Papampi »
there was a problem with qbittorent proxy settings,
disabled and enabled it and its all good
Papampi
Post by Papampi »
weird problem is that now every time i start qbittorent I should disable and enable proxy so that webui works.
any idea how to solve this problem ?
go to our download page and add our new PPAs. Update to v3.1.11 and see if it starts working.
Papampi
Post by Papampi »
Thanks for the reply
already updated to 3.1.11 from surfernsk ppa, and problem still not solved.
will add new repo and test again.
Papampi
Post by Papampi »
updated with official ppa and still same problem
should set proxy to none> apply , then set proxy http> apply
then webui will work
Can you use the unstable branch? The webui has seen major rework for v3.2.0 the past few weeks: https://launchpad.net/~qbittorrent-team ... t-unstable
Papampi
Post by Papampi »
Thnx, will test unstable and report back
ciaobaby
Post by ciaobaby »
Just as an aside to this, I'm getting 404 responses from both 'official' PPAs. on Linux Mint 16
W: Failed to fetch http://ppa.launchpad.net/qbittorrent-te ... urces  404  Not Found
W: Failed to fetch http://ppa.launchpad.net/qbittorrent-te ... kages  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
mint-16 chris #
The log says why. The PPAs don't have packages for the saucy version. Saucy isn't supported anymore by Canonical, thus I cannot make it build for it too.
I suggest you manually edit your /etc/apt/sources.list and add "trusty" instead of "saucy".
ciaobaby
Post by ciaobaby »
The log says why.
But it doesn't, it simply gives a HTTP: 404 response, and unless the user happens to know that a particular release 'code name' for Ubuntu is not "supported", it means nothing at all. I don't follow everything that Canonical does and I would guess that there is thousands of other users do not either
This is where the ENTIRE Linux community needs a very big kick in the rear, metaphorically speaking. If they expect to become a REAL force against M$ and Apple such things HAVE to a 'thing of the past'. The "That's how we've always done it and that's how it will always be done" attitude of the Debian "purist"  needs to become more user friendly.
Red Hat seem to manage it with CentOS perfectly well, I've yet to have a Yum update for anything  flake out on me because somebody couldn't be bothered to redirect a URL.
Papampi
Post by Papampi »
same problem with 3.2.0 alpha
also got a new problem ... keeps giving invalid username and password
only can get to webui when disable authenticaion for local host.
reset your username/password.
You cannot just redirect a URL meant for one version to another version. The packages from the other version may have unresolved dependencies for you(eg because they're using newer boost libs which aren't available on your old version)
@Papampi
Open a bug in our bug tracker describing the problem. Hopefully the webui devs will be able to fix this.
@ciaobaby, I updated the download page mentioning which ubuntu versions are supported and I give direct links to the PPA pages too. It should foolproof it now.
