Seeding - Not connecting
bitorbo
Post by bitorbo »
I'm seeding a few torrents with qBittorrent. I notice that peers appear on the list for each torrent now and again. They remain for a few seconds (sometimes 2-3, max. maybe 10-12 seconds).  But then they disappear.
The only peer that I see staying connected shows as using the client qBittorrent in the list.
Why are the other peers not connecting or being dropped?  Is it a problem with client compatibility?  Is the tracker or the peer deciding to prioritize another seed?
I'm not using very much of my upstream! :(
Re: Seeding - Not connecting
qbt version?
OS?
ciaobaby
Post by ciaobaby »
Yes!
bitorbo
Post by bitorbo »
sledgehammer_999 wrote: qbt version?
OS?
v3.1.11, Windows 7
Yes!
That was my guess but it seemed strange that the only peer happened to be qBittorrent.  I finally got a connection from another client application, today.
Is there a way to see how many seeds/peers the tracker has for a torrent?  I usually see this in other clients but I can't find it in qBittorrent. I only see active connections to me.
ciaobaby
Post by ciaobaby »
Trackers view on the information panel (Below the task list)
The trackers view isn't too accurate about peers. The "seeds" and "peers" columns in the transferlist should be more accurate.
To see if you have connection problems try to download a popular torrent like this one: http://releases.ubuntu.com/14.10/ubuntu ... so.torrent
