[Solved] qBittorent serious memory usage problems
windows filesystem cache is broken can we have an option to disable it in the windows client plz as it uses up almost all ram when checking large files
Re: qbittorent serious memory usage problems
Try the new 2.9.0 RC version available here. It no longer has this issue
Hi, didn't want to open a new thread so i'll write here.
I have a similar issue in W7 x64. Qbittorrent uses a lot of RAM when seeding (especialy at high speeds). RAM load slowly but steadily rises to about 3gb (out of 4 - that's when i close the client because the PC start moving like my grandma).
I should mention that in both Task Manager adn Resource Monitor, the RAM use of qbittorent appears "normal" (a couple of hundred) but when I close the client RAM use instantly drops to around 1gb.
I use the latest version of qbittorrent : 2.9.0.1
Any ideeas or solutions for this annoying issue?
Thanks,
Thanks,
[quote="sledgehammer_999"]Please look at the bug report. As a temporary solution we decided to enable the os cache again and I uploaded a 2.9.0.1 build. This should fix the IO errors, but, as a sideeffect, when you force recheck a torrent on Win7 64bit it will eat all the RAM.[/quote]
The bug report:
https://bugs.launchpad.net/qbittorrent/+bug/871328
We all hope this to be fixed soon. Try 2.8.5.
The bug report:
