Hi Guys,
Great forum here.
I have qbittorrent (latest version) but it wouldn't maximize. Having sloved that problem, I find to my dismay that Im being prompted for the Ui lock password. I didn't note it down thinking I could access it later. I have already re-installed but I'm still being prompted. Any ideas?
Best wishes
Bolkonski
qbittorrent password invalid
Re: qbittorrent password invalid
[quote="christophe.dumez"]You can edit ~/.config/qBittorrent/qBittorrent.conf and remove the following lines:
[Locking]
password=zzzzzzzzzzzzzzzzzzzzzzz
locked=false
Then restart qBittorrent.[/quote]
http://qbforums.shiki.hu/index.php?topi ... 418#msg418
[Locking]
locked=false
Thanks for helping out Ironcross, but as a newbie, how do I get in to edit? Where?
Best wishes
Bolkonski
Best wishes
Bolkonski
I don't know
I'm a Windows user. But i hope some of the Linux users here will help you.
Usually it's gedit so, given what ironcross provided, gedit ~/.config/qBittorrent/qBittorrent.conf
I'm not sure if you need sudo if that's the case then, sudo gedit ~/.config/qBittorrent/qBittorrent.conf
